Tachometer reading half RPMs?
Citori421
I have a yamaha pro series II tach for my 70TLR yamaha two stroke. I suspect it is reading half actual RPMs. The yamaha website states: "Pro Series analog gauges are offered in an illuminated, black-and-orange faceplate design. They’re engineered for those running F20 to F300 outboards".
I found that those motors are 12 pole (and four stroke of course), while my motor is 6 pole and two stroke. Am I correct that the tach is reading half of actual RPM? Thanks!
Alumarine
Did it ever work properly?
If not, I can only guess that it's not compatible with a 2 stroke.
does this help. based on your motor, your tach switches should be on, on, off if you have a 2-lead sensor, or off, on, off if you have a 3 lead sensor.
my guess is either switch 2 or 3 is in the wrong position
tach-settings-jpg.460984
Citori421
Thanks, I was finally able to pull my tach and behind the grommet there aren't those switches but there is a dial that selects either 4, 6, or 12 poles, and sure enough it was set to 12. I'm optimistic next time I take it out all will be well.
I think i mentioned either or in the other thread.. glad you are on the path
