hydra23
- Joined
- Mar 18, 2008
- 42
Hello, engine model Johnson J175exed. here are the symptoms. At 3,500rpm or above my tachmeter seems to re-set itself the alarm will sound one time and the 4 LED lights will recycle just like when the ignition switch is set to the on position. I have replace the tachmeter with an original OMC part, I have check and clean all connections including the grounds and the regulator/rectifier connections. Engine starts and runs OK. Voltage is 13.5 to 14.0 at all times. It will eventually drop to 12.5 or so to avoid overcharging. Can a bad ignition switch create this type of symptoms? Are there any other components that can create them? Do regulator/rectifiers go bad slowly or they just stop working at once? Thanks
