gbc_redfisher
Thread starter- Joined
- Sep 16, 2010
- 16
My Tachometer is not working at all.....
I know this has been done before...but I want to make sure i tested the Tachometer and both of my Voltage Regulators/Rectifiers before i go out and buy 2 of them. Here are some specs:
1999 Mercury 150hp XR6 Carb Engine
2 ea Regulators/Rectifiers - Mercury part # 854515
Each Regulator has (2) Red wires (2) Yellow Wires and (1) Grey Wire.
I tried out a new Tachometer first....still nothing...needle didn't move. I tried swapping the Grey (Sending) wire from the top Regulator to the bottom...and no change.
I disconnected all the Red/Yellow/Grey wires on both Regulators...with Ohm meter blk lead to ground...took red lead touched each wire individually one at a time and got a reading..ok
Reversed leads....red lead to ground....took blk lead and touched each wire individually one at a time and still got the same readings...not good?
To me, if I read what others wrote on here before...that tells me that both of my Regulators are bad.
Thats pretty much all i have done now....So, could someone confirm if I am correct in assuming that I need (2) new Regulators.
Thanks!
Thanks!
