Tachometer whacked out
wiretwister
83 Evinrude 115hp. The tach is nuts.....Reads ok for a few then might pop over to 8000 then to 3000 then read ok for a few....
Whats the problem??? Junk Tach??
Thanks
Wire
timalabim
Re: Tachometer whacked out
Could be your rectifier on its way out. I had the same symptom on my 96 112 johnson and soon lost all charging. Rectifier was fried. Look on the Johnson/Evinrude forum for the "small rectifier test". Replaced rectifier this spring and all is well.
wiretwister
Thanks........I will check that out.
Wire
