Tachometer with electronic ignition fitted?
Lurcher
Does anyone know if a standard car type tachometer will still work when the points set-up is removed from distributor and electronic ignition module fitted, my engine is a Ford Essex V6 marinised unit. many thanks. JD:confused:
bruceb58
Honorary Supreme Mariner
Re: Tachometer with electronic ignition fitted?
Should work the same.
