Tachometer
i57chevy
I had my vro pump removed and some other engine work done and my tach no longer works. I was trying to find a schematic of tach to motor, but my book does not seem to have that.
1996 v4 crossflow 90
Chris1956
Your tachometer needs power ground and signal wire to function. Power and ground come from the ignition switch. The tach should zero when the ign is switched on, engine not running. If not, check power and ground supply to tach.
The signal comes from the voltage regulator or rectifier, whichever you have. The tach signal is really the raw output of the stator. It is usually routed thru the VR or rectifier. It will be found on a yellow/grey or grey wire.
oldboat1
Failure of a rectifier (rectifier/regulator, if applicable) often means that the tach won't work. Is the battery charging?
An interesting sidelight with a failed water-cooled regulator (again if applicable) is a potential engine fire, so worth checking.
