tack issues
sun burn
got a 83 bartta 16' with a 120 mer.... tac. did not work when got it, hooked it up and it tacks out all the way (probably why unhooked) but will a regular tac. work just put it on 4 cly. should be the same right? and at wot what should be the rpms thank for any info.
Re: tack issues
Ayuh,... An automotive tach will work,...
Look for 4000/ 4400 rpms at wot....
sun burn
Re: tack issues
got tac in and hooked up, running right at 3600 rpm at wot so would this be to low
Re: tack issues
Ayuh,... At 3600 rpms at wot, she's Luggin',... Really Bad...
It either needs a Tune Up, or a smaller prop...
Don S
Re: tack issues
Or your tach is incorrect.
sun burn
Re: tack issues
had a 20 pitch 14 1/4 dim. turbo prop run at 3600 rpm put a quick sivler 21 pitch 12 somthing dimeter its stamped but in code or somthing getting a little over 4100 rpm water real ruff white capping only held wot for few sec.s........going to get better reading in calmer water
Re: tack issues
Ayuh,... Was it ventilating to beat 'ell,..??
That sounds like a mid-sized case Outboard prop...
Ya probably need a 19"... Maybe a 17"...
sun burn
Re: tack issues
Ayuh,... Was it ventilating to beat 'ell,..?? if this means what i call blowing out prop spining faster than it pulling water threw or calvtation it was doing that. so i thinking of the 17 pitch.thanks for the info..
