I have a 90's 2 stroke 8-hp outboard and over the weekend I noticed lower-end oil was leaking from the water drain when I put the motor in the tilt-up position. I checked the oil level and about a 1/4 of the oil has already dripped out. I refilled the lower-end so I could use it.
What do you think the problem is and how much should it cost to repair?
