Tahoe 195 I/O Horn
bergeronn
Does anybody know where the horn is located on a Tahoe 195 I/O? The reason why my horn doesn't work is because there are no words to the horn button. If I can locate the got, I'm pretty sure I'll find the wires.
achris
More fish than mountain goat
Are you referring to the engine warning horn?
If so, it should be in the wires behind the instrument cluster. One purple wire, one tan wire.
Chris....
bergeronn
Chris....
Thanks Chris. I found them. The wire cluster definitely hid them we'll.
bergeronn
Does anybody have the fuse block layout for a 2007 Tahoe 195 I/O? I have two spots that have fuses but no wires because they corroded off. Just trying to figure out which fuse goes where. Thanks.
bergeronn
Quick question for the starter for a Tahoe 195 I/O. I believe that bolt I have circled is where the 90a fuse connects to. My question is how do the three wires connect to the fuse? From what I can see in pictures I have seen, the + from the batter and the fuse both get connected to this bolt. Then the other red cable and orange cable get connected to the nut on the fuse itself. Does that sound correct? Just wanted to make sure before reconnecting everything.
you need a new starter. I would get the corrosion under control.
all those connections need to be cleaned to shiny metal.
bergeronn
Luckily, I know exactly what caused the corrosion, so now I can prevent it in the future. I planned on replacing the starter, but found a place that would trade in the entire boat so just trying to connect the cables back to where they belong with the new wires and fuse that I bought. Once I do that, I can put the boat back together and trade it in. 2019 Sea Hunt 211 here I come. :)
