tahoe Q6 06 fuel gage
maddog2112
My Tahoe Q6 has a problem with the fuel gage and I`m wondering if anyone out there knows how to solve it. When I fill it up the gage goes to just over 3/4 full, and it`s been as low as the black bars showing I`m getting close to reserve, but only took 20 gallons to fill back up. I`ve only had the boat a couple of months. I`m pretty sure it has a 33 gallon tank. Does anyone know of an adjustment or fix for this?:confused:
Silvertip
Honorary Supreme Mariner
Re: tahoe Q6 06 fuel gage
The diagram below shows a typical fuel sender. These are not especially accurate since fuel tanks are rarely uniformly shaped. The float arm can be bent and on some the float itself can be moved up and down the arm to affect the resistance element in that sends the varying voltage to the gauge. But here's the rub. You can't adjust for both empty and full accuracy. The idea is to adjust for EMPTY as you want to know when the tank is empty. You know when it's full because you filled it. Once you run a few tanks of fuel you will know roughly how much fuel you have at the 1/4, 1/2 and 3/4 readings. Look at a fuel tank as a cone shaped paper cup. If the level of fuel in that cup is half way been the bottom and top fo the cup the sender says you have 1/2 tank. You really have roughly 1/3 tank because there is more fuel in the larger upper half of the tank than the smaller bottom half. So the trick here is to remove the sender, measure the depth of the tank in the area of the sender. Then holding the sender perfectly upright with the float arm hanging down, measure from the sender mounting flange to the center of the float. Adjust the arm (bend it) or adjust the float so it is about 1/2 - 1 less than the tank depth. Reinstall the sender and when the gauge shows empty there should be about 1-inch of fuel left in the tank. The full reading will be whatever the gauge says.
maddog2112
Thanks, nice writeup. This will help me develop a plan or live with the problem.
SC Narc
I have an 06 Tahoe q6 as well. The fuel gauge is reading below empty despite tank being full. Any suggestions for troubleshooting?
SC Narc
I have the same boat but my fuel gauge is inop. Any suggestions for troubleshooting? Already visually inspected the float/sender unit and checked for loose connections.
