Tahoe trailer lights
maddog2112
Has anyone replaced the yellow or red trailer lights yet, and if so, where did you find them? I bought one yellow from a trailer store, but when I went to install it at home, I found it only had 1 wire as compared to the original 2 wire light on the trailer.:confused:
kailec00
Re: Tahoe trailer lights
Sorry, I have not had to replace any yet. I would try your tracker dealer. They may have some in stock, if not bet they could get you the right one.
I just replaced my trailer lights with LED versions. Very simple. Spliced right into existing wires.
I replaced the bar of 3 red ones on the bottom rear support of the trailer with LED's as well. It had 2 wires but the light bar only had one as it is grounded to the frame itself. Simply removed the old ground wire and spliced to the power wire. All works like a champ. LED's make a heck of a lot of difference.
maddog2112
Thanks for the info. I think I will check the led`s.
