Grumpy Bear
Thread starter- Joined
- Aug 23, 2014
- 58
Thanks ahead of time! Couple of short video clips to watch/listen to if you can. Motor is "warm" and warm-up throttle is now all the way off. Choke is off.
So, I have:
- Link & synced (at least 3 times to make sure)
- Carbs are clean and set to spec
- Turned out the carb idle screws about 1.25 turns or so (I've tried 1.5 and the result is basically the same)
- Checked compression, and it's perfect
- Made sure every plug wire is getting consistent spark and tested every spark plug
- Does not APPEAR to be any water in any cylinders. Some fouling but its black oil (this is a break in, so there's more oil in the gas to Merc's specs. Idling can cause some oily build up from what I understand). When I rebuilt it, I was very careful to clean off all gasket material, put on new, and tighten to spec, middle to out.
But it still runs at high idle and pretty rough as you can see/hear. If I put her in gear (which I really shouldn't do at 1200 RPMs) she still hesitates and dies. What do I adjust next??
First clip:
So, I have:
First clip:
