taking on water!
goosenoose
Hello I have a 99 gen 2 merc dripping water out of the shift cable on top of the intake what can I do to stop this? Is there a seal bad or something? Thanks
Re: taking on water!
Ayuh,... You need a New shift cable,+ it's bellows...
whit71
I would check exhaust manifold - riser - gaskets make sure its not squirting on to the shift cable. Good luck
Bt Doctur
The water inlet O ring is damaged or missing.Happens installing the drive.
