Re: Tandem Axle Trailer FLOATS!! What can I do to sink it?
Your trailer looks close to mine. If it was built in the south then the bunks could be cypress like mine were. I replaced with pin oak, which is what they use around here and the floating is gone.
You could fix the bad fit too, with new bunks. Not a hard job at all, just need a dock for a day or two. Up here, this time of year most boats are out of the water till spring so a lots of docks open. Try a local sawmill (one of the small farm type) for the lumber, it's cheaper and a rough cut is all you need. I did mine for under a couple of hundred for all the material, and thats all new bolts, carpet, SS staples, and wood.
If you got the cash the aluminum bunks like Lakes84's are sweet.
huts
