Tandem towing
tazrig
Re: Tandem towing
no you don't.... I have to lock the steering on the jeep and let the front wheels scrub but with a boat back there I can back it up pretty easily.... The only reason I have ever had to back up is because there was an accident ahead of me that closed the highway so I backed up a couple hundred feet to make a u turn..... Otherwise, If you have to back up then you weren't paying attention.... You only pull into places that you can pull out of.... I look at the parking lot at a gas station from the road and pass it by if it's not big enough for me.
taking corners is no different than if I only had the fifth wheel... the jeep actually tracks slightly outside the tires of, but still inside the rear outer corner of the camper.
How can you back up with 3 pivot points? I didn't think that was possible. Isn't it like trying to back up with a tow dolly?
smokeonthewater
Re: Tandem towing
it's technically possible to back up with a tow dolly too but the very short length between the two pivots would make it VERY difficult and you couldn't see that part at all so it would be jacknifed before you could react.... My first two pivots are 38' apart so I have plenty of time to react and can see it really well... You just have to think ahead and get used to turning the wheel the opposite way (turn right to sent last trailer right) and you have to start sooner because reaction of last trailer will be delayed twice because you have to turn the tow rig to turn the first trailer to turn the last trailer......... It DOES take a WEE bit of practice to get good at it ;)
I've seen guys that can back semi doubles around corners... That's 4 pivot points and the lengths are short long short long.... That is just plain AMAZING to me
This is just straight but I watched a guy do it around a corner at night in the rain while I stopped traffic for him.... I was VERY impressed.
http://www.youtube.com/watch?v=dKpJyIbEfDc
tazrig
Re: Tandem towing
4 pivot points?! WOW! Well, I won't feel bad for myself any more just fighting with 2.
BOWTECH.JUSTICE
Re: Tandem towing
Lots of good info here. Thank you all. For me I think I will have to experiment before I try to do it for real.
