Tandem Trailer Suspension - Equalizer after Tire Change
skydiveD30571
I jacked up the boat/trailer and put it on jack stands to take the 4 wheels to a tire store and mount the new tires I just bought. The 2 jack stands were placed under a crossbeam in between the two axles. Before I jacked it up, the suspension looked like below, with the equalizer centered:
When I came back, put the wheels back on, and lowered the trailer the equalizer settled into an uneven position similar to below (cropped from etrailer video):
Is that something that settles back into position with time? Or maybe after some driving? The eTrailer folks don't mention it so I can't imagine it's a big deal but I thought I'd ask. I tried to reset it by jacking the trailer up and down a couple times but it always settled into this position on both sides.
Re: Tandem Trailer Suspension - Equalizer after Tire Change
Ayuh,.... It oughta settle in, as soon as ya move it,....
smokeonthewater
raise or lower the tongue and you'll see it even out
skydiveD30571
Thanks I'll keep an eye on it the first couple times I tow.
A couple weeks ago while doing routine trailer maintenance I adjusted the drum brakes so that each wheel spun 1-1.5 revolutions on its own. When I was installing the new tires and wheels, I tried again and 1 spun very freely and other barely moved. I trailered about 10 miles in between. Are they getting out of adjustment that fast?
T_Herrod
Do the brakes have self adjusters on them? Or maybe the shoes were not centered up good when you adjusted them. Your suspension should get back to normal with a little pulling down the road. Did you check the temp of the hubs?
bruceb58
I have never seen a trailer brake with self adjusters on them.
skydiveD30571
Bondo you're right...about 15 feet and I heard a loud "clunk" as they both settled into place. Thanks all.
Idlespeedonly
Just an fyi, Some of the Dexter surge brakes have self adjusters on them.
wrench 3
When manually adjusting brakes you should adjust them up tight to center the shoes and then back them of so they spin.
Idlespeedonly
No I dont.
wrench 3
Interesting set up. Works in forwards instead of revers.
bruceb58
Is there a hydraulic version?
skydiveD30571
I saw that Etrailer has 10" Demco hydraulic drum self-adjusting brakes.
