Beefer
Thread starter- Joined
- Aug 4, 2008
- 1,737
Hi all. I recently bought a 16' Bayliner Capri, and it had two portable fuel tanks, a 6.5g, and a 3g. On our maiden voyage, we topped off the tanks, and headed out for a short run (about 10 miles round trip). Well, that didn't go so well, as it seems the gas that was in the tanks was either bad from sitting, or had water in them, and we were left DOW about a mile from home, with about 4 gals left in the tanks. I dumped the remaining fuel (proper disposal at the marina), and decided that next time out we would take an extra 5g in a can. Ok, no problems, but we decided to change the fuel setup. I'm now running the 6.5g, another new 6g, and the 3g as reserve. It's a pain in the transom to stop the engine, switch tanks, and proceed as desired.
I was thinking about installing a brass T-connector, and run both tanks at the same time, making the effective fuel capacity of 12.5g, or adding in a 3-way (or 4-way) valve, and just switching as needed. If I do the valve, can I just turn the handle without stopping the engine, or will there be a break in the flow? Also, with either setup, where would I put the fuel/water filter? Or would I need 2?
If anyone has any other ideas, I'd love to hear them. Thanks!
