Is it normal when "tank testing" a 3hp in a 35 gal. drum as the motor runs WOT for it to sound like it revs slightly high then a bit lower and back up again due to all the water sloshing around in a small area ? Not real noticable but not a smooth purr like on open water. Also after running about 5-10 minutes the water had a thin film of oil on top , is this normal from exhuast ? I was running a rich mix to test about 18:1-Thanks
