Re: Tank testing a motor. Do I use prop to test?
shops use a a test wheel, but unless you have a fairly large tank, i dont think even that is an option. not a good idea to remove the prop as its very easy to over rev and damage the motor. backyard tank running is usually limited to not much more than a fast idle in gear unless you are running a small motor, and even then the motor can bail out your barrel faster than a hose can refill it at wot.
