Tankless Hot Water Heater Recommendation
roscoe
" The line going from the tank to the house was 1 1/2" "
Seems a bit off to me.
I have 1/2" copper tube to the regulator, then 1" black into the house.
Does just fine with a 70,000 but furnace and a water heater.
Maybe running at different pressures ???
bruceb58
I am not saying you need 1 1/2". You may need greater than what you have depending on the distance of your existing lines.
My tankless was 180K BTU.
bruceb58
35K may be common for a tank water heater. It is not sufficient for a tankless especially if the water starts out cold.
bruceb58
Tankless was 160-190k that I've been seeing....
I looked up The Rinnai chart for pipe size. You should probably be ok. I remember it being way more conservative. Go down to the propane table:
Every elbow reduces the equivalent length so you would need a table for that too.
bigdee
The only reason to get one is if you don't have space for a tank.
The efficiency difference is small. If you don't descale it every 6 months or yearly, you lose all the efficiency gains. They don't work when you lose power. If a part needs to be replaced, it may take over a week to get. If you live in a very cold climate and power goes out for an extended period of time, it may freeze. With a tank water heater, you have an emergency supply of water...
With the Rheem that I had, the flame sensors would get soot on them so it would error out and lock up. I would have to take the whole burner assembly apart every 2 months to clean. Only reason I replaced it with another tankless was because I had al ready repurposed where the tank used to be.
Was thinking about a tankless for my vacation rental. Thought better of it since I would lose thousands of dollars if it went out before a rental. Plus in the case of my vacation rental, the water heater is inside the house anyway so the heat lost from the tank just heated up the house anyway.
I went Noritz for my second tankless after talking to a repair place when I was having problems with my Rheem. They suggested the Noritz.
BTW, that 35K BTU heater you have in there now is tiny. If you do decide to go up to a bigger tankless unit, make sure your gas line is big enough to support it. My house was also on propane. The line going from the tank to the house was 1 1/2" and I was able to tap off of it. If you have a 3/4" line for a good part of your distance, getting a 90K BTU one might be a problem. Ignore this if you are using an electric version.
I agree with bruce......simplicity and reliability go hand in hand.
bruceb58
160-190 but is a lot more than I would have expected.
Even with that, you can only run 2 fixtures at the same time in Southern California where the cold water temp starts out higher than most places. Up in Wisconsin where Musky is, likely only 1. The BTU requirement goes up the colder your initial water temp is. There is a chart that shows desired water temp rise vs GPM.
WIMUSKY
Yeah, we a have a well. It gets pretty cold....I'm starting to lean on replacing the tank. Take the old one out, hook up a new one, done..... Simple and save a bunch of money... Put money saved into traveling fund.....🚍
captmello
swap it out with a 50 gallon and call it a day.
WIMUSKY
