Generally, you cannot reliably measure coil primary resistance with the average multimeter. Even Fluke get pretty "iffy" down in the low ranges. Also regardless of what you see on the internet, you can NOT reliably test a coil with a multimeter, either for good or bad, with the possible exception of condemning one with a shorted/ partly shorted secondary. That is, If you have reliable specs on the secondary resistance.
