Taylor made half horsepower deicer
Lickers1
Just put my deicer in the water plugged it in and it tripped the ground fault. The motor turned on initially but then turned off when the ground fault tripped. I took it out of the water and plugged it in to a ground fault and tripped that as well. Any idea why it is tripping the ground fault?
My guess is there is corrosion within the deicer
Lickers1
Do you have testing instruments?
I do have some testing meters but I have to be honest I don’t know exactly how they work. Unit is only two years old. If you can explain what you want me to do I probably can figure it out. Appreciate your help
DeepCMark58A
Can you turn that pump impeller by hand or with a screw driver? If it th shaft was locked it would trip a brake if th windings ar bad th GFCI would trip.
crazy charlie
Probably some condensation or water intrusion in the motor casement.
I would manually turn the impeller several turns.Shake the unit upside down
and place it in a very warm dry place for a few days.(my boiler room is like a sauna) . you can leave it on the seat of your vehicle on a sunny day .Try it again after that.Let us know if it works.Charlie
mike_i
We don't have ice where I live so I have to ask, what is a deicer?
submersion pond pump that hangs from a float to keep ice from forming around your boat by keeping water flowing
Lickers1
Thank you I will try that. I was thinking about taking the impeller off and putting my drill on the shaft and let it run for a while. But I will do what you suggest and see what happens. I will let you know. I just need to make sure that it’s not going to trip again after I put it back in the water if I can get it to work on the land Without it tripping
