Bt Doctur
Thread starter- Joined
- Aug 29, 2004
- 19,566
Tech Tip with the single point drain system, be sure to remove the quick connect fittings on both sides of the block.
They do close with scale and corrosion . The same thing happens with the so-called flushing system. The block connection become closed from corrosion and will not allow it to drain properly or allow fresh water into the block to flush it.
Also ,there is no way to drain a block or manifold with this type of system.So if your thinking of just introducing it with a running engine
THINK AGAIN
My current rate to dress and replace an engine is $1600 plus the cost of the engine.You decide
THINK AGAIN
