Techrom metor
csisommout
Hi, any one, I have 1999, 30 hp, Mercury with oil in jection. There is 1 connector from side control. Is that for techro metor? Thank you
csisommout
Re: Techrom metor
additional pix, just adding to the text. thank you
carholme
Re: Techrom metor
Presumably your mean tachometer and if so, that should be the plug for it.
Do you have the wiring diagrams? If not send me a PM and I will send you a copy of the service manual.
Do you have your engine s/n?
Gerry
canoemang
Re: Techrom metor
Yes.. that looks like the pig tail for the tach..
csisommout
Re: Techrom metor
what of Tech do I need for it? can some one direct me to the right part. thanks
csisommout
Re: Techrom metor
how do I send you a pm? never done it before, tell more. Thank you,
carholme
Re: Techrom metor
That s/n is 0G762519 and it comes up as a 40hp:
MARINER - ( 40 H.P. (1999 ))
Serial No: 0G762519 Model No: 7041227HD
To send a PM. go to Notifications up at the top of the page, next to where it says Welcome csisommout, click on it and go to your inbox. From there, you can select Send a New Message from the box on the LH side of the page. Enter my name, carholme in the recipient box, type the message and click Submit and I should get the message. If someone sends you a message, there will be a number next to Notifications to advise you that you have a message.
Gerry
csisommout
Re: Techrom metor
I think s/n 06762519. the motor is new to me. Thank you.
csisommout
Re: Techrom metor
edit serial number. looks like0G762515. Thank you
