Re: ted williams eska 9.9 hp
Post a model number. You could have a sticking float, a sinking float, or a torn fuel pump element. It's llikely fuel overflowing the carb. You gotta pull it off, thoroughly clean it, and shake the float - if it's leaking, you hear the fuel in it. Look at the mounting face of the carb when you pull it, and you'll likely see an orange circle with a slot in the face of it. Yank it out, and roll it between your pinched fingers while looking closely for splits or tears. That your fuel pump element, and it's driven by vacuum pulses from the bottom end of the crank case. When you find your model number, enter it here, and do a model number search;
http://www.searspartsdirect.com/partsdirect/index.action
Don't get parts there, get parts from these guys;
Results for ESKA - Sears / Ted Wms
Or call these guys with your model# and part numbers;
VinParts
Do NOT turn that motor over without grounding the plugs or the wires, you can trash your ignition system, and you don't want any of that.
PS - Post a model number.
Oh, and did I mention that you should probably post a model number?
