Teleflex Temp Gauge Install Questions
Geezer1
I purchased a temperature gauge kit for outboard motors (#58862P comes with sender and "z" bracket) to install on my 1973 Evinrude 135. The included instructions only discuss motors far newer than mine. I do however, understand the "z" bracket install, with one exception. Should I install this bracket under a head bolt, or under a head cover bolt? I've spent a good deal of time researching this, and just about everything I've read says mount under head bolt. My head bolts would not offer any surface for sender contact on the head if the "z" bracket were used, but would offer plenty of surface if mounted on the head cover. I would sure appreciate a picture from anyone who is actually mounting the assembly under a head bolt. While on the subject, I'm thinking that the ideal area to mount this type of sender is high up on #1 cylinder. Any thoughts on that as well would be appreciated. Geezer.
emdsapmgr
Re: Teleflex Temp Gauge Install Questions
I don't think there is a hard and fast rule either way. More one of personal preference. My Z brackets usually have a fairly small hole for mounting to the engine. It's easiest to use a head cover bolt, as it's a 1/4" bolt. No need to use a head bolt, which involves having to drill out/enlarge the z bracket hole, then retorque the head bolt. A typical Z bracket is the right size/length for head cover mounting.
Geezer1
Thank you for your response. My concern was that I may not get as accurate a reading from the covers. I suspect that what I probably would be looking for would be consistency, rather than accuracy. I'm going to mount the sensor on the cover of cyl #1, as high as I can get it.Thanks again. Geezer.
sinkererswim
First off, I have no experience in this matter..............
But, I would think I'd be more interested to know the temperature of the head itself rather than a cover?
