Television Removal Tool?
dalesking
I have a 2003 Carver that came from the factory with a flat screen Panasonic TV mounted in a recess in the wall. I need to remove the TV for service but can't see how to get it out of the pocket. It will pivot a couple of inches right or left, but not enough to see how it is secured.
Is there a special tool or method to remove the TV?
ezmobee
Re: Television Removal Tool?
Couldn't resist
rbh
There is probably going to be a mounting bolt or two below or behind the cubby hole, or look for nuts.
The Great Escape II
Check underneath the TV there might be 2 screws that the TV bracket is attached to the cabinet bracket. That's how our LCD mount is on our boat.
