I just bought a used bass boat (1987 Glasstream 1550) that has the 70hp 1980 Evinrude. Engine seems to be in great shape. Cold cranks very easy as long as you know to push the key in to activate the primer lol. Runs smoothly, idles fine.
This is the first large outboard and bass boat I've ever owned. I'm a cabinet maker and have also done truck cylinder head swaps and rear-gear swap/setup so I have some mechanical understanding. So anything you guy share I'll appreciate greatly.
Prop is a SS 13-3/8 dia x 17 pitch. Gets up on plane ok but has to be fully trimmed down (see below, engine is a 20" on a 15" transom). It handles fine, not as bad as you might imagine with a longtail engine.
The boat itself is in beautiful shape for such an old girl. It lacks any engine telemetry gauges so I'm buying a tach and would like to put temp gauge at some point.
I've ordered the Seloc and also OMC shop Manual for it.
Anyhow, I'm looking for the following info, and ANYTHING you guys can share that might be known problems with this engine.
Does this have an overheat alarm? Is this something that is a part of the control panel (throttle panel), or in the engine cowl?
Is there an hour meter buried in this thing somewhere?
This motor is unfortunately a mismatch. It's a 20" shaft on a 15" transom. Prop center is roughly 7" below pad. Can you guys suggest a budget, but trustworthy static jack plate? I definitely cannot afford a powered jack plate.
Would a whale tail/hydrofoil assist getting up on plane at lower speeds? I basically have to hole shot it at WOT but once it planes it will hold it ok at about 1/2 throttle which is my preferred cruising speed because of stumps.
