I have a 2002 mercury 200 outboard with carbs.The tell tale stream is constant but low pressure at idle,I know this is probably normal but how hot should the stream be? It feels like hot tap water,you can hold your finger in the stream but just a few seconds or it will scald you and this is with the motor warmed up. I'm new to boating,I just bought this boat so I'm still learning.
