skynyrdcat
- Joined
- Mar 11, 2007
- 157
1991 Suzuki 65 HP
Just put a new impeller in (and plate below the impeller)...
Have a good stream for a while, then drops to a trickle.
Getting plenty of water blown out the exhaust.
I think the stream may be trickling when the T-stat opens.
Could be a piece of rubber from the previous impeller (I thought I got it all out) but since the stream is strong at times (usually at start up) I'm thinking I may not have enough water pressure.
Any thoughts or things I should look for?
impeller is orientated correctly and the key is in place, pump housing had some slight wear marks but they didn't look excessive.
