crazy charlie
Thread starter- Joined
- May 22, 2003
- 5,753
I noticed recently that the telltale stream on my 95 150 Ocean pro is a bit erratic.Usually it is uniform and it looks now as if there is a small obstruction in the valve causing the stream to be ununiformed(if that is even a word).I flush through the pisser after each use so I checked for anything in it and found nothing.I idled the motor without the pisser valve in and then reinstalled it to find the same uneven stream.Motor temp is the same ,nice and cool,ran it the entire next day. Should I look further or leave it alone.Still plenty of water coming out,it is just not a uniform stream.Charlie
