Searay87
Thread starter- Joined
- Sep 10, 2009
- 106
The Faria temperature gauge on my 87 sea ray seville 17BR 3.0L mercrusier jumps back and forth (instantaneously) between 175F and 250F with a delay of about 4-5 seconds (re :reads 175F for 5 secs then jumps to 250F and stays for 5 secs). I've checked the actual engine block temperature with my handheld non-contact IR thermometer and the highest temp I measured was 176F where the water exits the block into the exhaust manifold. I'm thinking this is an electrical problem. I replaced the thermostat and the sending unit at the end of the season last year and all was well at that time. I've removed, cleaned and tightened the connection on the seding unit. Has anyone experienced this problem? Any thoughts on what else I can check?
Thanks!
Thanks!
