I have a 2007 Bayliner 175 with Mercruiser 3.0 TKS. My engine water temperature gauge has stopped working, needle just shows the minimum value, 100 degrees all the time. I grounded the sender wire at the engine and the gauge deflected to fully pegged. I thought this meant the gauge was good so I replaced the sending unit sensor. This didn't fix the problem. Then I replaced the gauge, still not working. Any ideas? Might it be a thermostat problem? The housing around the thermostat doesn't seem to get very hot while running. The engine seems to run fine, even at WOT.
