Temp gauge Mercruiser 3.0 not working
johnt_mn
I have a 2007 Bayliner 175 with Mercruiser 3.0 TKS. My engine water temperature gauge has stopped working, needle just shows the minimum value, 100 degrees all the time. I grounded the sender wire at the engine and the gauge deflected to fully pegged. I thought this meant the gauge was good so I replaced the sending unit sensor. This didn't fix the problem. Then I replaced the gauge, still not working. Any ideas? Might it be a thermostat problem? The housing around the thermostat doesn't seem to get very hot while running. The engine seems to run fine, even at WOT.
itsathepete
Do you know if there is actually have a thermostat in there? Gauges, especially at lower temps are not terribly accurate. They are pretty much designed to be "close" at the operating temp and are more of a guide. Put an IR temp gun on the engine block, thermostat housing and exhaust manifolds while running to tell for sure
johnt_mn
I'll check the IR reading when I get home, but I do know that in the past the temp gauge has always shown around 175 degrees (needle straight up) while running. Currently it never budges from 100 which is the lowest value on the gauge.
