Fair Boater
Thread starter- Joined
- Jul 29, 2002
- 13
I have a 73 Johnson 115 OB with a temp gauge in the dash that doesn't register (stays at low-temp side of gauge). I assume (man, I HATE that word) the gauge to be original as it matches the others in the dash.<br />The gauge is properly grounded, as the running light operates. I have cleaned and reset all connections. Is there an easy way to test the gauge? <br />The gauge's "sender" wire is soldered to a wire that runs between two "temp-sensors" in the bottom two cylinders. <br />Can someone explain how the temp system is supposed to operate? The owner's manual states that the temp-sensors act as a switch for a temp alarm horn. If this is the case, how does the sending wire receive a variable reading for the gauge?<br />A voltmeter connected between the solder joint and ground (also between "sender" terminal of gauge and ground) reads +12V with the ignition on, motor running. This reading never changes.<br />Any help is appreciated in advance! Thanks for reading this novel!<br />Bob
