Re: Temp gauge wiring question please!
Thanks jtexas for info, yes I did get sensor with gauge, you take out one bolt put sensor against head type, I thought that a seperate battery was the way to go to keep main battery for starting only? so probably to keep it simple I would be better to just use main battery for my gauges, I have speedo, cylinder head temp, and water pressure, the water temp is only one with wire to engine, they will all have the lights working on them with switch. thanks again for help, JBD
