temp gauge won't work
trooperjim
I have a 4.3 that was just rebuilt. I installed a new thermostat and water temp sensor. If I ground out the wire, the water temp gauge pegs. On the garden hose, the starboard exhaust/water (thermometer in the water stream) is 140 degrees and the port side is 110 degrees. My gauge starts at 120 degrees but won't register the 140 degrees or show any movement at all. Any suggestions? I bought the boat with a bad engine and know nothing about the history of the boat. Thanks.
fishinpa
Re: temp gauge won't work
did you use sealer or tape on the threads for the sender ??
fish
trooperjim
No. I didn't add anything to it. It has the kind of orange coating on the threads that it came with. It wasn't working before, so, I'm thinking it might be something else?
Lyle29464
I would hook a ground wire to the sender case and see if that does it. Your system may by-pass excess water to the exhaust giving you a low reading. The orange stuff may not let the sender read correct.
trooperjim
I hooked a ground wire to the thermostate housing and the gauge came alive. Thanks for the help!
Ayuh,... The orange thread sealer shouldn't be a problem,...
But,...
When you reinstalled the T-Stat Housing,.. Did you use the Right gaskets, Marine gaskets,..??
There's supposed to be a brass crush rivet in the gaskets for continuity...
Sounds like your's Don't...
pwpns
trooper jim I noticed in a earlier post you talked about your engine stumbling and backfiring above idle. How did you correct the problem I have a 99 Stingray with a 4.3 that I just rebuilt that is doing the same thing
trooperjim
It turned out that the distrubitor cap was bolted to the base 1/4 turn off by the machine shop. Be sure to check your index marks on the distrubitor cap to make sure everything aligns up. the Male piece was pressed down so I guess he didn't notice that there was a slot for it to fit in. Didn't think it would make a difference but, it did...instantly!
