kneedragger
- Joined
- Feb 1, 2004
- 61
I have a 94, 4.3 liter LX, with the holley 4 barrell, Engine number 14099090M
My temp gauage is not working all of last summer, and I am trying to diagnose the issues. The intake manifold/thermostat housing has two wires one Brown w/ blue stripe (Starboard side) (i think is the temp Guage), and one solid brown (Port Side) leading to two different brass hex head sending units.
In reading searched posts on this subject, I understand to check to make sure the guage is working, to gound the wire to the block and see if it is pegged hot. However, most of what was researched only dealt with one wire.
I grounded both wires, and the guage does not move. However, If i bridge the wires together, I get a maximum hot reading on the guage.(hope I did not fry anything)
Also, with the motor NOT running, after a about 30 seconds, my alarm will sound.
First and foremost, I want to fix the guage, then worry about the alarm, and they may be connected.
What do each of these sending units do? Are they wired correctly, and can I test them?
Thanks for the help!
