jam1ej20
- Joined
- Mar 31, 2009
- 111
I have a 1995 4.3 mercruiser and the temp gauge isn't working. Here's what i've done, any advice is appreciated.
-Gauge tests good per merc manual.
-With key in run position, gauge bounces slightly when lead is placed on and off of temp sender (indicating connectivity of lead wire)
-When temp sender and switch leads were switched, low tone could be heard from warning bell. After the problem was realized, the leads were corrected and the gauge worked for the first time for about 30mins. The gauge then dropped back to cold and has not worked since. I assume that the sender is (or at least WAS) working since the warning bell emitted the low tone while connected to the sender instead of the switch.
I have not actually tested the sender yet, and just wanted to sound off here before I go to the trouble of running that test to see if anyone had any insight to other potential problem areas.
Thanks!
Thanks!
