temp issue 150 mariner
ysb
good evening everyone, need some advice on a 150 mariner, 1985 model. my temp runs about 1/2 way on gauge at idol and up to 3/4+ on gauge @ wot. the engine dosent appear to be hot, you can lay your hand on the heads their hot but not boiling or scorching i installed a new, temp sender for the warning system and its working if you ground it, the alarm sounds. new thermostats new waterpump, new poppet. i have a 200 degree melt stick and it dosent melt it. cant find sending unit for this motor. any ideas?
Faztbullet
Re: temp issue 150 mariner
If the alarm horn works and not sounding and needle is not on H it not getting hot. This is the reason I hate guages as there is no set spec, cold at one side and hot on other and nothing in between and give false ideas of something wrong. Replace it with a water pressure guage ....my $.02
ysb
where do you install the gauge in a 1985 150 mariner no outlet
