baytonemus
Thread starter- Joined
- Jun 23, 2010
- 217
I was able to acquire a wiring harness and junction box (with no regulator) from a salvage yard for my 40352D - Big Twin Electric. The service manual wiring diagram shows a tan wire running from the temp warning light back to the temp switch on the motor. There is no tan or any other color wire for this in the wiring harness and I'm not sure what to make of that.
Also, the temp switch wire on the motor has no connector, so I assume it was cut off at some point. Were these switches prone to failure? Removing it for testing would appear to require that I replace the head cover gasket in the process.
Lastly, It seems to me that either replacing that warning light with a horn or buzzer, or at least adding one to the circuit, might really be a good idea. I'm wondering if anyone has done this successfully with a simple motorcycle horn, for instance.
Thanks.
Thanks.
