New to the site, and I figured I'd give this a shot.
I have a 292 in-line 6 w/ and alpha 1 gen 1 drive. The motor is 3 years old, with 300 hours on it. Since I put the motor in, I have been running cold (no thermostat). The temp basically stayed at 125 deg at all times once warmed up. Last year I was running home, and my temp alarm went off and the gauge read 210. I immediately shut down and was assisted home. My immediate thought was my impeller, and since it was the end of the season, I came out of the water. I replaced the impeller and all associated seals and heat tube.
Went in the water this spring and immediately noticed my gauge rising. I took the riser and manifold off and flushed it out (they looked good with no blockages or scaling). INstalled them and started haing the same problem.
Pulled the intake and ran it into the bildge. Pleanty of flow. I then changed the raw water pump, eventhough the old one was new when motor was installed. On idle, the temp began to rise up to 165/170, but far much slower than it did previously. I went for a short spin. Once I brought her up to 2600-2800 rpms, she dropped to her normal operating temp. If I picked up the rpm to 3k or more the temp climbed again.
When I got back in, on idle the temp started to fluctuate from 130 up to 180, and continues to bounce back and forth. She even climbed up over 200. I do not believe I was running that hot because my alarm would have gone off. So, I changed the sender.
Now my temp on cold start was ver 200. There was no major fluctuation, and steady over 200. I changed the gauge and no change, still over 200. i ran new wires from the battery and sender as a sanity check, but no change.
I am now completely frustrated and lost. Anyone have any idea??????
