temp sending unit
jimcavy
i have a 1993 mariner mag 3 150 hp and i had to replace the tempature sending unit and tempature guage. the sending unit is sits in a hole one on one of the heads. there was a gel or lubricant used to transfer the heat from the head to the sending. what is that gel or lubricant?
Thanks
Also i disabled the oil injection system, i want to keep the warning buzzer for over heat but it is put of the oil injection system warning module. is there a way to fake out the oil warning side of the module?
Thanks for the help
Jim Cav
Chris1956
Re: temp sending unit
Jim, Normally that motor would have a temp warning sender on each head. They would be connected together on the starboard side of the motor, and run to a buzzer. I did not think they were part of the oil warning system. I never saw a Temp Gauge sender, on that motor. Is it an option?
jimcavy
you are right there is two sening units one is for the warning module and the other is for the guage. I had to replace the guage because it failed why i dont know. i just decided to replace the sending unit two just to be safe.
