Temperature sender confusion
DamianJP
Hello again
Im trying to install a temp gauge but when I looked , both cylinder heads have a sender or sensor.
The alarm in the remote box works fine just got a new temp gauge and need to find the sender, then hook it up to a gauge.
The above pic is hooked up to this area by the stater solenoid.
This one as you can see isnt hooked up to anything, I found it taped off.
Im confused to which one I should hook up the gauge to.
Thanks in advanced,
DamianJP
mrallen007
Re: Temperature sender confusion
Hmmmmm.... I can't say I'm positive, but generally speaking mercury's default wiring schemes would say the solid tan wire is the sender for the temperature guage.
DamianJP
Hello
Thanks mrallen007 got the gauge in and a line going back to motor, just gotta wait for powerhead install to hook all the lines back up. If I get no reading its gotta be the sender.
Thanks again,
DamianJP
