O. Thats interesting. Would a knock sensor be useful on a engine with a carb? I always thought knock sensors were for EFI.Knock sensor…
I have wasted a lot of time looking for the drain plug that a new knock sensor will fit in with no luck . If you have a part number that would be great.That’s called a Knock sensor…
Would you like help finding the part number for the drain plug?
Engine serial number helps some but not totally needed for this item… again if needed or desired.
Go to NAPA. Ask the old guy behind the counter. They probably have both T's and Y's in stockI have wasted a lot of time looking for the drain plug that a new knock sensor will fit in with no luck . If you have a part number that would be great.
Blue plug is item number 50 in the link of post number 4 above next to fitting numbers 48 and Knock sensor 47...O-ring (51) comes with a new plug.I have wasted a lot of time looking for the drain plug that a new knock sensor will fit in with no luck . If you have a part number that would be great.
| 50 | 8M0119211 | PLUG KIT, (.500-13) Royal Blue, Fitting | 806608A1 | SS/ACT |
| $9.40 | $9.17 | Quan Used 5 |
ThanksLinks to sensor manufacturers in the electrical forum stickies
Look at the SMP (standard motor products) catalog
Yeah you can use a standard 1/4” npt. Just be aware that the blue plugs do not have a NPT thread on them. I think they are 1/2” coarse so it is not a regular pluming fitting. If I recall I thought there was a thread on here on the knock sensor being a standard GM part. The knock module is a GM part ….179 dollars for a knock sensor! I would never go cheap for important parts like brakes or suspension parts but there aint no way in heck I am going to pay 179 for something that wont kill my engine if it should **** on me. And mercury wants 95 for a brass fitting! NOT! I am sure a trip to the plumbing section at my local hardware store will get me something a hell of a lot cheaper and better than what merk has to offer.
Got lucky and found this.........https://www.amazon.com/Quicksilver-...hvlocphy=&hvtargid=pla-4583520390117562&psc=1Yeah you can use a standard 1/4” npt. Just be aware that the blue plugs do not have a NPT thread on them. I think they are 1/2” coarse so it is not a regular pluming fitting. If I recall I thought there was a thread on here on the knock sensor being a standard GM part. The knock module is a GM part ….
looks like the same chit
1991-1995 GM Ignition Knock (Detonation) Sensor 10456126 | GM Parts Center
Save Big On This OEM GM Ignition Knock (Detonation) Sensor, Part #10456126 for 1991-1995 GM. Wholesale Prices, Fast Shipping. Order Online Today!www.gmpartscenter.net
ACDelco 10456549 ACDelco GM Genuine Parts Knock Sensors | Summit Racing
Free Shipping - ACDelco GM Genuine Parts Knock Sensors with qualifying orders of $109. Shop Knock Sensors at Summit Racing.www.summitracing.com
