67Johnson6HP
- Joined
- Jun 14, 2007
- 103
78Rude6hp - Anyone know how to tension the throttle return spring (I believe that's the correct description) on the carb. Whoever "rebuilt" it didn't adjust the spring or or maybe broke it (I don't tnink so) so they rigged another spring somewhere else (which is too strong) to close the throttle. I'd like to "fix it right" and thought someone here might have some expertise on this. I had torn apart and cleaned the whole throttle grip assembly 'cause it was hard to turn. Turns out that that stiff spring was causing problems as well.
Thanks.
