Terhi Big Fun, drilling holes
jack daniels marine
Hi folks, I have a 1997 Terhi big fun which is made from ABS plastic with foam in between the inner and outer layers.
I want to mount a Garmin echo 150 transducer on the transom.
Is it ok to drill 2 of 5/32in holes , 1 in deep into the lower transom of such a boat?
I dont know if the area is reinforced with wood, foam or something else under the ABS plastic.
Any experience would be appreciated.
Grub54891
Re: Terhi Big Fun, drilling holes
I'd contact the mfg and ask them. You may have to drill and inject some sort of epoxy in before mounting it. I would think the transom is built with something stronger than foam.
Grub
jigngrub
may want to consider a suction cup mount transducer instead.
