SuperMiguel
Thread starter- Joined
- Oct 5, 2009
- 82
How can i test a trailer brakes?? it has disc brakes
Are they surge brakes or eletric. If electric, just apply the toggle on the brake controller. If surge, try backing up without inserting the lockout pin...
i guess mine uses this: http://www.overtons.com/modperl/pro...iler-Brakes-Hubs&aID=603I&merchID=1009&r=view
where do i connect this?
One of the pins in your 7 way plug says reverse or back up. the wire goes there. If yours doesnt have it for some reason then you can wire it to a toggle switch and operate it when needed, just done forget it.
In fact forget i mentioned that last part.
Just disconnect the connection betwen the truck and trailer and try to back up. You will be able to tell.
Its next to the brake fluid reservoir. It has the break away chain on it.
filled the reservoir since it was empty and pulled this while spinning the wheel and no go![]()
Was there any fluid in the res? If not, then you may need to bleed the brakes to get the air out of the system.
If you have that reverse backup system that wires to you backup lights, then unplugging the lights should disengage that switch and allow the brakes to engage while backing up.
If there is air in the lines, they will not engage until the lines are purges of air and the system primed up...
