Testing compression...in water or not?
JohnWI
Trying to decide how bad it is to test compression while out of the water?
Seems that to do all cyl's for 6 seconds each isn't tooooo, bad, but then again, running the impeller dry is never a good thing. I recall seeing some damage that supposedly happens over a very short period of time if ran dry.
Also wondering if it might be slightly inaccurate (of a reading) if done in the water as there will be some additional drag on the engine so the battery might not quite spin it as hard? Then again, if the rubber impeller doesn't have the water to lubricate it, it may run harder when dry that in the water.
BonairII
Re: Testing compression...in water or not?
Hook it up to a set of muffs when your testing compression. Problem solved.
JB
Remember that a few psi don't matter unless they are the difference between cylinders. A working impeller is critical to engine survival.
boobie
And make sure you take all the plugs out when doing it.
