58CorrySuburban
Thread starter- Joined
- Sep 28, 2008
- 73
I'm new to outboards, so when I went to check the compression on my cheaply aquired 35hp Big Twin I expected the worst.
First test upper cylider = 30lbs?
Secons Test (same cylinder) = 30lbs?
I stepped back and took a breath. There was no way I was sold a parts motor.
Being new to these enginse, I reexamined it. Ahah!
The Pin conected to the SS flat bar was relieving the compresion (making it easier to start under normal conditions.
I disconected the arm from the release vaulves.
Second test w/out presure release valves in effect:90+ psi, the second cylider read 100+
All tests were run cold and I lubed the interiors with Blast.
Any insight would be apreciated.
Thanks
Thanks
